Page 2 of 2
Re: Firefox as default for all users
Published: March 22, 2018 - 2:52 PM
by sfonteneau
gaelds wrote: ↑March 22, 2018 - 2:49 PM Until yesterday, I was installing a 32-bit Firefox package everywhere, but the latest "lesfourmisduweb" packages uninstalled this 32-bit version to install the 64-bit version. There remains a "C:\Program Files (x86)\Mozilla Firefox" folder on the machines, but it is almost empty.
This behavior in my package has not changed between the latest firefox package and previous packages.
Published: March 22, 2018 - 3:43 PM
by gaelds
Yes, it's strange, but it's been happening since the update to 1.5.1.21 and/or the replacement of my firefox_all package with firefox_x86+firefox_x64. It's still the 32-bit version that used to install on our 64-bit PCs; I don't know why.
Published: March 23, 2018 - 2:54 PM
by gaelds
I found a workaround to allow users to open desktop URL shortcuts in Firefox by modifying the registry. However, the commands to set Firefox as the default browser are not working.
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\Associations\UrlAssociations\http\UserChoice]
"Progid"="FirefoxURL-308046B0AF4A39CB"
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\Associations\UrlAssociations\https\UserChoice]
Published: January 22, 2019 - 3:34 PM
by Jonattend
I'm having the same problem and I wanted to know how you set up your registry key?
Did you push the key via a WAPT package?
On which systems was this tested? (Windows 7/Windows 10?)
Thanks ;)
Published: January 25, 2019 - 3:35 PM
by Jonattend
After many hours of research and testing, I finally managed to set Firefox ESR 60.4 as the default for all users.
For this, I rely on this utility: https://kolbi.cz/blog/2017/11/10/setdef...uild-1607/
My WAPT package: firefox-esr-default:
        killalltasks('firefox.exe')
        filecopyto('SetDefaultBrowser.exe','C:\Program Files\Mozilla Firefox')
        run(r'"C:\Program Files\Mozilla Firefox\SetDefaultBrowser.exe" HKLM Firefox-308046B0AF4A39CB')
def session_setup():
If you run "wapt-get session-setup ALL" on a machine, an error appears regarding the firefox-esr-default package, BUT the modification works. This occurs on both local and domain accounts.
Yours sincerely.
