Page 2 of 2
Re: Flash installation error
Published: February 9, 2017 - 2:15 PM
by Omahaddict
I just tried it as you suggested.
Here's the error message I got when I tried installing the MSI.
After digging a little deeper, it seems to be a bug caused by the MSI update of Flash, while previous versions were installed via the web installer (which is the case on some machines...).
Flash provides a tool for uninstalling it, `flash_player_uninstaller`, which can be run silently with the `-uninstall` option.
What do you recommend for cleaning up my system?
I thought about creating a package with the uninstall tool that would be a dependency of the Flash Player package so that it runs first, and then incrementing the Flash Player package so that it redeploys correctly on all machines. What do you think?
Published: February 9, 2017 - 4:33 PM
by sfonteneau
I tried at one point to include flash_player_uninstaller in the package. But that didn't solve the problems. A cleanup should be included at the beginning of the package
Published: June 19, 2017 - 3:50 PM
by cdeze
I'm encountering this problem too, have you found a solution?
installation of Java (JRE)
Checking old java 8...
Installation JRE 32bits
2017-06-19 15:53:06,095 WARNING error for 32797920
2017-06-19 15:53:06,141 WARNING error for 32844144
2017-06-19 15:53:07,842 WARNING ('msiexec /norestart /q /i "jre1.8.0_111.msi" ',) command returns code 1603
2017-06-19 15:53:07,842 CRITICAL Fatal error in install script: EWaptSetupException: Fatal error: MSI jre1.8.0_111.msi has been installed but the uninstall key {26A24AE4-039D-4CA4-87B4-2F32180111F0} can not be found:
File "c:\wapt\common.py", line 3379, in install_wapt
File "c:\windows\temp\wapt_qqu7m\setup.py", line 54, in install
install_msi_if_needed('jre1.8.0_111.msi',killbefore=['firefox.exe','chrome.exe','iexplore.exe','jushed.exe'])
File "c:\wapt\setuphelpers.py", line 3434, in install_msi_if_needed
error('MSI %s has been installed but the uninstall key %s can not be found' % (msi,key))
File "c:\wapt\setuphelpers.py", line 3593, in error
raise EWaptSetupException(u'Fatal error: %s' % reason)
2017-06-19 15:53:08,434 CRITICAL Package dsi-java8 not installed due to errors: EWaptSetupException: Fatal error: MSI jre1.8.0_111.msi has been installed but the uninstall key {26A24AE4-039D-4CA4-87B4-2F32180111F0} can not be found
installing WAPT packages dsi-java8
Installing dsi-java8
Results:
=== install packages ===
dsi-java8 | dsi-java8 (8.111-23)
=== errors packages ===
Published: June 19, 2017 - 4:57 PM
by cdeze
Okay, sorry about this message, version 8.0.131 seems to work better...
