Page 2 of 8
Re: Creating Edt/Pronote package
Published: August 21, 2017 - 2:26 PM
by olaplanche
running `uninstall()` in PyScript doesn't work, but the `uninstall.iss` file is generated correctly. If I copy it and use it to run the uninstallation command in a command prompt, the uninstallation completes successfully.
Therefore, I'm ruling out a problem with creating the `uninstall.iss` file; there must be an issue with executing the uninstallation command through PyScript.
Thank you.
Published: September 1, 2017 - 11:31
by dcheynel
I'm a beginner with WAPT. I haven't created any packages yet, but the installation on my network is already working.
Could you make your Pronote package available so I can test an import method other than the packages offered by TIS?
Thank you very much.
Published: September 1, 2017 - 4:14 PM
by olaplanche
my packages are customized to create a connection shortcut to our Pronote server.
If you wish, I can modify my package with the DNS name of your Pronote server before sending it to you.
Published: September 4, 2017 - 10:54 AM
by dcheynel
I'd like that, although I think I'll be able to change this setting when editing the package.
My Pronote server address is:
https://0350700w.index-education.net
Thank you
Published: September 5, 2017 - 2:52 PM
by olaplanche
Hmm, I must have missed something! I sent you a private message, but it's stuck in the outbox...
Did you receive it?
Published: September 6, 2017 - 9:20 AM
by dcheynel
thank you very much,
I imported the package into my repository and it works.
Have a nice day.
Published: September 6, 2017 - 10:13 AM
by olaplanche
with pleasure.
Have a good start to the new school year!
Published: June 19, 2018 - 09:22
by Aghaton
I'm writing because I'm also looking for this Pronote package to better prepare for the next school year.
Olaplanche, I would also be interested in your Pronote package. Would it be possible to provide it to me? (I would make the necessary modifications to personalize it for my school.)
Thank you. Have
a good day.
Published: June 19, 2018 - 1:33 PM
by olaplanche
Package sent!
Best regards,
Published: June 21, 2018 - 11:56
by Aghaton
Hello, as I couldn't reply to your private message, I wanted to thank you here.
Thank you and have a good day. :)
