Re: WAPT 1.3 to 1.5 Migration Error
Published: Dec 12, 2017 - 11:55 AM
I performed an apt-get remove / update / clean / install again, but the error is still present.
I use this repository:
Is this the right deposit?
EDIT: Apparently, this is the right one
The version corresponds to the one previously indicated in the topic (nightly build)
But the error is still there
deb https://wapt.tranquil.it/debian/wapt-1.5/ stretch main
Préparation du dépaquetage de .../tis-waptserver_1.5.1.9-tisdeb9-4425-ef7b7b4b_amd64.debBut the error is still there
2017-12-12T12:07:36.536+0100 connected to: 127.0.0.1
2017-12-12T12:07:36.603+0100 exported 6 records
WARNING:root:Traceback (most recent call last):
File "/opt/wapt/waptserver/waptserver_model.py", line 424, in update_host_data
existing = Hosts.select(Hosts.uuid, Hosts.computer_fqdn).where(Hosts.uuid == uuid).first()
File "/opt/wapt/lib/site-packages/peewee.py", line 4941, in select
query = SelectQuery(cls, *selection)
File "/opt/wapt/lib/site-packages/peewee.py", line 3016, in __init__
self.require_commit = self.database.commit_select
File "/opt/wapt/lib/site-packages/peewee.py", line 439, in __getattr__
raise AttributeError('Cannot use uninitialized Proxy.')
AttributeError: Cannot use uninitialized Proxy.
CRITICAL:root:Error updating data for [SECRET] : AttributeError: Cannot use uninitialized Proxy.
File "/opt/wapt/waptserver/scripts/postconf.py", line 511, in <module>
main()
File "/opt/wapt/waptserver/scripts/postconf.py", line 338, in main
mongo_update_status = check_mongo2pgsql_upgrade_needed(waptserver_ini)
File "/opt/wapt/waptserver/scripts/postconf.py", line 241, in check_mongo2pgsql_upgrade_needed
run_verbose("sudo -u wapt /usr/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres")
File "/opt/wapt/waptserver/scripts/postconf.py", line 68, in run_verbose
output = subprocess.check_output(*args, shell=True, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 219, in check_output
subprocess.CalledProcessError: Command 'sudo -u wapt /usr/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres' returned non-zero exit status 1
