[SOLVED] Files corrupted, SHA not matching
Emmanuel64
Registration: February 23, 2024 - 09:37
September 16, 2026 - 10:21
Hello everyone
@dcardon
Thank you for your feedback
I didn't see any "Edge" processes running in the background, but Microsoft knows how to trick us :D
@t.heroult
Thanks for the info, this alternative is indeed easier than installing via .exe files
Just in case, I used MeshCentral in PowerShell (completely transparent to the user)
# Trouver la clé "Edge"
Get-ChildItem "HKLM:\SOFTWARE\Classes\Installer\Products" | Where-Object {
    (Get-ItemProperty $_.PSPath -Name ProductName -ErrorAction SilentlyContinue).ProductName -like "*Edge*"
} | Select-Object PSChildName, @{N="ProductName";E={(Get-ItemProperty $_.PSPath).ProductName}}
# verifier la clé (optionnel)
Get-ItemProperty "HKLM:\SOFTWARE\Classes\Installer\Products\<clé_trouvée>"
# Supprimer la clé
Remove-Item "HKLM:\SOFTWARE\Classes\Installer\Products\<clé_trouvée>" -Recurse -Force
# Installation via wapt (ou via la console)
wapt-get install tis-microsoft-edge
WAPT Enterprise
Version 2.7.0.19593
Server OS: Debian Trixie
Administration machine OS: W11
x-davidl
Registration: Apr 25, 2022 - 5:07 p.m.
September 16, 2026 - 3:07 PM
Hello Emmanuel64,
this is an elegant solution to (in my case) prevent it from searching for a previous .msi file that it can't find.
My error is that Wapt fails because the new MSI is looking for the MSI that was used for the installation.
Deleting the registry key with Mesh in PowerShell then validates the installation.
Many thanks
. Best
Emmanuel64
September 16, 2026 - 3:12 PM
Glad I could help.
On my end, everything is back to normal, except for a few jobs that will patiently wait for Monday's WithSecure update.
Have a good day!
WAPT Enterprise
Version 2.7.0.19593
