Page 1 of 1
[Resolved] Problem with the registry
Published: February 27, 2018 - 09:19
by dsp
I have a small problem; when I try to modify the
HKEY_CURRENT_USER For example:
registry_setstring(HKEY_CURRENT_USER,r'Software\Microsoft\Windows\CurrentVersion\Internet Settings','toto1','tata1')
The Wapt agent on the other machine makes the change in the
HKEY_USERS.
Did I do something wrong?
Sincerely
Re: Problem with the registry
Published: February 27, 2018 - 09:48
by agauvrit
This is what is called a context problem.
The beehive
HKEY_CURRENT_USER refers to the current user context, therefore during package installation (function
install() ), this refers to the local SYSTEM user of the machine.
During your tests, this must have worked very well since the modifications are made in the hive of the user account used for package development.
But once the package is pushed to the workstations, the changes are not made in the user hives.
If you need to make changes to the user hive, you should therefore execute the function within the user customization context by defining the function
session_setup():
def session_setup():
The documentation on this subject:
https://www.wapt.fr/fr/doc-1.5/Creation ... index.html
Alexander
Published: February 27, 2018 - 10:20 AM
by dsp
Thanks for your quick reply, it works better when things are done correctly ^^
