Page 1 of 1
[SOLVED] Is wapt-get register required after installing the agent?
Published: March 14, 2018 - 1:42 PM
by Eric
WAPT version: Debian server WAPT 1.5 RC1 community.
I have a problem with the new version of WAPT: My clients don't automatically connect to the server after the agent is installed. I have to type the command `wapt-get register`.
What is the cause and is there a way to fix it?
(Client workstations are running Windows 10, registered on our Active Directory server.)
Thank you
Re: Is wapt-get register mandatory after installing the agent?
Published: March 14, 2018 - 1:44 PM
by sfonteneau
Can you specify your configuration?
Kerberos authentication?
Basic authentication?
No authentication (like version 1.3)?
Published: March 14, 2018 - 1:47 PM
by Eric
Without authentication (like version 1.3)
Published: March 14, 2018 - 3:06 PM
by sfonteneau
If the agent fails to send its inventory, it attempts a register. I just tested it, and it works.
Can you provide the wapt-get.ini file for your agents?
Is antivirus software installed on the workstations?
Is the WAPTService running correctly on the workstation after installation?
Published: March 19, 2018 - 5:06 PM
by Eric
Sorry, I had a big problem to fix last week and couldn't get back to WAPT.
Anyway, thanks to your questions, I was able to solve the problem: in the wapt-get.ini file, the server's .crt certificate wasn't at the correct address (it was looking for it in the administrator's roaming profile).
I regenerated an agent with the correct parameter: C:\Program Files (x86)\wapt\ssl\server\waptsrv.mydomain.fr.crt, and now everything is working perfectly.
However, the "agent generator" had apparently used this address by default (or perhaps I had changed it and I don't remember?).
Thanks
Re: [SOLVED] Is wapt-get register mandatory after installing the agent?
Published: March 19, 2018 - 5:14 PM
by sfonteneau
To avoid this kind of problem, we have implemented a security measure in version 1.5.1.21
