Page 1 of 1
[RESOLVED] wmi_info & remote commands
Published: March 23, 2018 - 5:56 PM
by empbilly
Hi folks,
How can I declare the wmi_filter option? Can it be as below?
wmi_info(keys=['Win32_NetworkAdapter'])['name']['index']
Re: wmi_info
Published: March 23, 2018 - 7:17 PM
by dcardon
Hi Empbilly,
empbilly wrote: ↑March 23, 2018 - 5:56 PM Hi folks,
wmi_info gives out a data structure out of wmi module. You can just print the data structure or its inner parts:
wmi_data = wmi_info(keys=['Win32_NetworkAdapter'])['Win32_NetworkAdapter']
print wmi_data
print(wmi_data[0].keys())
for item in wmi_data:
    print item['Caption']
Cheers,
Re: wmi_info
Published: March 23, 2018 - 8:45 PM
by empbilly
From the example above, I could make a script that disable via wapt, for example a computer wireless card?
Re: wmi_info
Published: March 24, 2018 - 11:33 PM
by dcardon
Hi Empbilly,
empbilly wrote: ↑March 23, 2018 - 8:45 p.m. From the example above, I could make a script that disable via wapt, for example a computer wireless card?
wmi_info() just give out a python list/dict datastructure with information for inventory. You cannot do any action out of that wmi_info() function. However you can import wmi python module and use it in your script.
Regarding the specific subject of your question, if you have the name of the interface, then you could use netsh with something like:
netsh interface set interface "network_adapter_name" admin=disable
But it is not always easy to get the network_adapter_name right, especially if your Windows is not an English one and has accent in the name...
Cheers,
Re: wmi_info
Published: March 26, 2018 - 7:46 PM
by empbilly
Okay. I'm trying to make the script below work. The problem is the accent on the text "Conexhaso local 2" that the "con" variable receives. I tried several ways to decode and encode to utf-8, but without success.
>>> con = 'Conexão local 2'.decode('utf-8')
>>> print con
Conexão local 2
>>> con
u'Conex\xe3o local 2'
How can I solve this problem?
import subprocess
    print "Instalando Wi-fi adapter disable"
    try:
        x = subprocess.Popen(["cmd.exe", "/c", "wmic path win32_networkadapter where NetConnectionID='%s' call disable" % (con)], stdout=subprocess.PIPE, shell=True)
        print (x.stdout.read())
    except (RuntimeError, TypeError, NameError):
        print "Erro na execução do cmd.exe"
Re: wmi_info
Published: March 26, 2018 - 9:27 PM
by empbilly
Now it works!!! :D
# -*- coding: UTF-8 -*-
import subprocess
import locale
con = u'Conexão de Rede sem Fio'
    print u"Exercutando Wi-fi card disable"
    try:
        x = subprocess.Popen(["cmd.exe", "/c", "wmic path win32_networkadapter where NetConnectionID='%s' call disable" % (con.encode(locale.getpreferredencoding()))], stdout=subprocess.PIPE, shell=True)
        print u"Erro na execução do cmd.exe"
Re: [RESOLVED] wmi_info & remote commands
Published: March 26, 2018 - 9:34 PM
by vcardon
Hello Empbilly,
I see portuguese comments in your script to disable wifi connections, are you writing from Brazil?
If that's the case, that would be just cool to start having WAPT in South America.
If your language is Portuguese, do you feel it would be useful to have WAPT internationalized in Portuguese, or do you feel that adminsys are sufficiently familiar with English where you live?
Thanks.
Vincent
Published: March 27, 2018 - 02:14
by empbilly
Yes. I live in Brazil and work in an education institution.
:D
I think it would be great to have, mainly, the wapt documentation in Portuguese. Speaking of the sysadmins of our institution as a whole, more or less about 20 campuses, the vast majority do not have an intermediary to advanced skills in English.
