Migration 1.3 -> 1.5 under Centos 7
Published: March 30, 2018 - 2:54 PM
I followed the procedure as explained on page https://www.wapt.fr/fr/doc/waptserver_u ... entos.html but I encountered some errors during the procedure.
In case this might be useful to others, here are the changes I had to make to successfully complete the migration:
To uninstall wapt 1.3:
becomes :
In the section Update the CentOS / Red Hat server :
becomes :
(MongoDB is split into two packages under CentOS: mongodb-server and mongodb. The mongodb package contains mongoexport, which is used by the migration script.)
I also executed the following command so that the migration script could check for the presence of the lock file:
I patched the file /opt/wapt/waptserver/waptserver_upgrade.py (I only used (current_distrib != "centos linux" because I don't have a rhel7 machine on hand to test if the initial script also needs modification to work):
I also patched the /opt/wapt/waptserver/scripts/postconf.py file because under CentOS the daemon is not called mongodb but mongod:
To resign packages from the repository, modify the commands specified on the page https://www.wapt.fr/fr/doc/waptserver_u ... regenerate by changing /var/www/wapt/... to /var/www/html/wapt/...
yum remove tis-waptrepo tis-waptsetup tis-waptserver
systemctl stop apache2
systemctl disable apache2
systemctl stop httpd
systemctl disable httpd
yum install postgresql94-server postgresql94-contrib
yum install postgresql94-server postgresql94-contrib mongodb
chmod 755 /var/lib/mongodb
--- /opt/wapt/waptserver/waptserver_upgrade.py.orig 2018-03-29 15:00:58.908069144 +0200
+++ /opt/wapt/waptserver/waptserver_upgrade.py 2018-03-29 15:12:00.480088326 +0200
@@ -67,7 +67,10 @@
"""Connect to a mongo instance and write all wapt.hosts collection as json into a file"""
if platform.system()=='Linux':
mongo_datadir = '/var/lib/mongodb/'
- if 'dbpath' in subprocess.check_output('mongoexport --help',shell=True):
+ distrib_tuple = platform.linux_distribution()
+ current_distrib = distrib_tuple[0].lower()
+ print ('detected distrib : %s ' % current_distrib)
+ if ('dbpath' in subprocess.check_output('mongoexport --help',shell=True)) and (current_distrib != "centos linux"):
data = subprocess.check_output('mongoexport -d wapt -c hosts --jsonArray --dbpath=%s' % mongo_datadir,shell=True)
data = subprocess.check_output('mongoexport -c hosts --jsonArray --db wapt',shell=True)
--- /opt/wapt/waptserver/scripts/postconf.py.orig 2018-03-29 15:51:46.261262372 +0200
+++ /opt/wapt/waptserver/scripts/postconf.py 2018-03-29 15:52:12.043380391 +0200
@@ -234,8 +234,12 @@
def upgrade2postgres(configfilename):
print ("mongodb process running, need to migrate")
run_verbose('sudo -u wapt PYTHONPATH=/opt/wapt PYTHONHOME=/opt/wapt /opt/wapt/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres -c "%s"' % configfilename)
- run_verbose("systemctl stop mongodb")
- run_verbose("systemctl disable mongodb")
+ if type_redhat():
+ run_verbose("systemctl stop mongod")
+ run_verbose("systemctl disable mongod")
+ else:
+ run_verbose("systemctl stop mongodb")
+ run_verbose("systemctl disable mongodb")
def nginx_set_worker_limit(nginx_conf):
already_set=False
PYTHONPATH=/opt/wapt PYTHONHOME=/opt/wapt python /opt/wapt/wapt-signpackages.py -i -s --message-digest=sha256,sha1 -c /root/wapt-private-20180312-1522.crt /var/www/html/wapt/*.wapt
PYTHONPATH=/opt/wapt PYTHONHOME=/opt/wapt python /opt/wapt/wapt-signpackages.py -i -s --message-digest=sha256,sha1 -c /root/wapt-private-20180312-1522.crt /var/www/html/wapt-host/*.wapt
