Page 1 of 1
[RESOLVED] WAPT Console
Published: April 17, 2018 - 10:10 AM
by waptuser92
After installing the server on Windows, I can't find the "waptsetup-tis.exe" agent file from my local server's web interface to install it on a WKST database. I get a 404 error from the web page, and I can't find the file on the server itself.
Can I recreate it or download it from elsewhere?
WAPT Server version: 1.5.1.21
WAPT Agent version: 1.5.1.21
WAPT Setup version: N/A
WAPT Deploy version: 1.5.1.21
Database status: OK (1.5.1.21)
Thank you for your help.
Re: WAPT Console
Published: April 17, 2018 - 7:42 PM
by dcardon
Hello Waptuser92,
waptuser92 wrote: ↑Apr 17, 2018 - 10:10 AM After installing the server on Windows, I can't find the "waptsetup-tis.exe" agent from my local server's web interface to install it on a WKST. From the web page, I get a 404 error, and I can't find the file on the server itself.
Waptsetup is installed along with the Wapt server on Windows. Therefore, you can directly launch the console from your Windows Wapt server and create your agent.
If you want to install the management console directly on a machine other than the server, you can still download waptsetup-tis.exe from the Tranquil IT website https://wapt.tranquil.it/wapt/releases/ Be careful to select the file corresponding to your version. However, do not install it on the server, as the files are already provided by the waptserversetup.exe installation
Re: WAPT Console
Published: April 18, 2018 - 10:14 AM
by waptuser92
Thanks for the info.
