Page 1 of 1
antivirus software
Published: May 3, 2018 - 7:21 AM
by Thai53
As far as I know, different Windows PC operating systems have different software and antivirus programs. My system is Windows 10, and I want to know which antivirus software is best suited to prevent malware without affecting the computer's speed and performance.
Update: Thank you very much, I already saw your comment. My question has been resolved; the answer I received is from this article: https://pcmaintenant.net/meilleur-antiv ... c-windows/
Re: Antivirus software
Published: May 3, 2018 - 09:24
by vcardon
Thai53 wrote: ↑May 3, 2018 - 07:21 prevent malware, and it will not affect the speed and performance of the computer.
If you want the Software Restriction Policies, see https://docs.microsoft.com/en-us/previo ... 2(v=ws.10).
"You can also use software restriction policies to create a highly restricted configuration for computers, in which you allow only specifically identified applications to run. Software restriction policies are integrated with Microsoft Active Directory and Group Policy. You can also create software restriction policies on stand-alone computers.
Software restriction policies are trust policies, which are regulations set by an administrator to restrict scripts and other code that is not fully trusted from running."
WAPT allows you to master SRPs effectively.
Antivirus then becomes a complement to your SRP strategy, or even SRPs completely replace your AV.
Sincerely;
