Page 1 of 1
[RESOLVED] WAPT Private Repository Settings
Published: May 4, 2018 - 10:34
by mohondit
I installed WAPT version 1.5 a few weeks ago, but my colleagues can't access the external Tranquilit repository when they're on the console. When I try to add it in the repository settings, I get this error message:
"An unhandled exception has occurred
HTTPError:400 Client Error: Bad Request for url:
http://myserver.lan/wapt/Packages".
However, everything works fine on the administrator account I used for the installation.
T
Re: WAPT Private Repository Settings
Published: May 4, 2018 - 11:12
by sfonteneau
Can you provide the waptconsole.ini file for the session where it works and the session where it doesn't?
%localappsata%\waptconsole\waptconsole.ini
Published: May 14, 2018 - 08:25
by mohondit
I made changes to the "%localappdata%\waptconsole\waptconsole.ini" file on the computer where it wasn't working, so that it was identical to the one on the working computer.
And it's all working now, thank you.
Published: May 14, 2018 - 10:04 PM
by vcardon
mohondit wrote: ↑May 14, 2018 - 8:25 AM Hello,
I made changes to the "%localappdata%\waptconsole\waptconsole.ini" file on the computer where it wasn't working, so that it was identical to the computer that was working.
And it's all good, everything works, thank you
Good morning
To help others who might encounter a similar situation, ideally you should post the mistake you made, however minor, and its correction; everyone has the right to make mistakes and everyone has the right to benefit from the solutions to others' mistakes—that's how humanity progresses. Then, as an added bonus, marking the forum post as resolved would be a huge help.
Combining these two actions would be a real big bonus for the forum's activity.
This forum will increasingly be driven by the community and somewhat less by Tranquil IT staff, so improving one's personal good practices will benefit everyone.
In any case, congratulations on your choice of WAPT.
Sincerely.
Vincent
