Page 1 of 1
WAPTservice startup error
Published: May 25, 2018 - 11:52
by DCOSNEFROY
I'm having a problem with the latest Windows 10 workstations I deployed in my organization. The agent installation goes smoothly, the workstation appears correctly in the console, but immediately switches to "UNREACHABLE." After some research, I have the following information:
- The WAPTservice is paused, and when I try to restart it, I get the error "Windows could not start the service... The service did not return an error..."
- I launched debug mode (waptpython waptservice\waptservice -l debug), and my workstation then communicates correctly with the server (contact, deployment, etc.).
- I restart the workstation, and the same problem persists.
I tested with the Windows firewall and antivirus disabled, and the problem remains.
Has anyone else encountered this kind of problem?
Thank you
Have a good day.
David
Re: WAPTservice launch error
Published: May 25, 2018 - 7:03 PM
by sfonteneau
What version of Wapt
is it? Is the nssm.exe file present?
Published: May 28, 2018 - 1:04 PM
by DCOSNEFROY
I'm still on version 1.3.8.2.
Yes, the nssm.exe file is present.
Thanks,
David
Published: May 28, 2018 - 2:40 PM
by sfonteneau
You need to upgrade to version 1.5; this problem has been resolved
Published: May 28, 2018 - 2:46 PM
by DCOSNEFROY
Okay, I'll do the update quickly.
Thanks
Have a good day,
David.
