Page 1 of 1
tis-waptrepo 1.5 and nginx
Published: May 25, 2018 - 3:46 PM
by TomTom
I just built a remote repository for one of our branches.
Following the documentation "https://www.wapt.fr/fr/doc/Replicate_Mu ... index.html" nothing works.
The difference is that the new tis-waptrepo package configures nginx and no longer Apache.
Do you have an updated procedure?
Thank you in advance.
Re: tis-waptrepo 1.5 and nginx
Published: May 25, 2018 - 3:57 PM
by sfonteneau
TomTom wrote: Hello,
The documentation points to https://wapt.tranquil.it/debian/
So we install a Waptrepo in version 1.3 with Apache. This should work
Published: May 25, 2018 - 4:10 PM
by TomTom
Thanks for the reply.
If I use the old repository:
E: The repository 'http://wapt.tranquil.it/debian ./Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) man page for repository creation and user configuration details.
Hence my configuration using the new repository, which I thought would work...
Published: May 25, 2018 - 6:59 PM
by sfonteneau
Yes, indeed, we need to replace it in the documentation with: https://wapt.tranquil.it/debian/wapt-1.3/
