Page 1 of 1
[SOLVED] mass forget package
Published: August 8, 2018 - 2:13 PM
by empbilly
I know that I can do this manually, but is there any way to select and have mass forgotten packets that are no longer part of the host?
Re: mass forget package
Published: August 27, 2018 - 1:15 PM
by empbilly
Anyone have an idea if my question posted above is possible?
Published: August 27, 2018 - 2:30 PM
by htouvet
Make a multi-selection of the target hosts (Ctrl+Click / UpperCase+Click) and make the focused one has the package you want to forget, then right click on the package / Forget.
Published: August 28, 2018 - 4:59 PM
by empbilly
htouvet wrote: ↑August 27, 2018 - 2:30 p.m. Make a multi-selection of the target hosts (Ctrl+Click / UpperCase+Click) and make the focused one has the package you want to forget, then right click on the package / Forget.
Thanks htouvet!!! Works!!! :)
