Page 1 of 1
No action possible after update 1.5.26
Published: August 29, 2018 - 4:13 PM
by mohondit
I just updated to version 1.5.26 and I'm encountering some problems.
After completing the agent update, the waptupgrade package was automatically updated in the repository. I then tried to apply it to my machines, but none of my actions were being applied (see attached image).
Normally, I have a 1 in "actions," but now it's 0 no matter what I do… And when I go to the "tasks" tab for my machines, I get this message: "Unable to retrieve action. Error on server: Timeout, client did not send result within 5.0 s."
Could I have missed a step?
Thank you in advance.
Re: No action possible after update 1.5.26
Published: September 5, 2018 - 3:41 PM
by htouvet
When an action is "Skipped," it generally means the machine you're trying to reach is connected to another server (or appears as such in the database).
Are you sharing the WAPT server database between two WAPT servers, or have you kept the database with the server's UUID?
Check the /var/log/daemon.log file when the machines connect. Any errors will be reported.
When a machine connects (via WebSocket) to a WAPT server, the WAPT server writes the WebSocket session ID and the server's unique ID to the database.
