User authentication is not working
Published: September 10, 2018 - 4:53 PM
on a recently deployed machine, user authentication is not working when installing a package via the web interface!
Tested with other accounts in the user's session, everything works fine.
The user is indeed a member of the waptselfservice group.
After some investigation:
A `gpresult /r` confirms the user's membership in the waptselfservice group.
Tested on another machine => Failed.
The machine appears correctly in the console, as does the list of installed software.
Command line:
`wapt-get install` => error 401;
`wapt-get update` => OK.
Version 1.3.13.0
Command line:
Version 1.3.13.0
