Page 1 of 1
[RESOLVED] Valid SSL/TLS certificate for the WAPT server
Published: September 25, 2018 - 2:19 PM
by James
this might be a silly question, but can WAPT clients use HTTPS server certificate verification with a self-signed certificate?
It's not very clear in this documentation:
https://www.wapt.fr/fr/doc/Installation ... ertificate
"This self-signed certificate will not be recognized by browsers and will not allow for proper verification of the WAPT server."
Thank you.
Re: Valid SSL/TLS certificate for the WAPT server
Published: September 25, 2018 - 3:09 PM
by htouvet
Yes, the WAPT client will verify the certificate, whether self-signed or not.
The difference is that for a commercial certificate, the client already has a list of certification authorities (from "certifi")
In the case of the "authorized" self-signed certificate (which the WAPT client trusts for HTTPS connections to the repository and server), it is distributed during the installation of the custom agent waptagent.exe. It is placed in C:\Program Files (x86)\wapt\ssl\server\ and is referenced in C:\Program Files (x86)\wapt\wapt-get.ini
via the "verify_cert" parameter
[global]
verify_cert=C:\Program Files (x86)\wapt\ssl\server\srvwapt.ad.tranquil.it.crt
Post-checking can be enabled on a client using the command (cmd with Admin privileges elevation)
wapt-get enable-check-certificate
Re: [RESOLVED] Valid SSL/TLS certificate for the WAPT server
Published: September 28, 2018 - 10:38 AM
by James
Okay, that's perfect!
In the WAPT configuration, I check the "Verify server HTTPS certificate" box, and specify
the path to the CA bundle. I click the "Get server HTTPS certificate" button, and it retrieves the certificate from C:\wapt\ssl\server\srwwapt.domain.crt.
When I validate, I get an error: "
Error connecting with SSL.
error:14090086:SSL
routines:ssl3_get_server_certificate:certificate verify failed."
Do I need to generate a new certificate? (Knowing that I changed the hostname along the way...)
Thanks
Published: October 1, 2018 - 4:41 PM
by htouvet
The CN of the certificate used by the HTTPS server must match the hostname of the URL used to access the WAPT server (wapt_server and repo_url)
