Page 1 of 1
Empty depot
Published: November 16, 2018 - 11:45 AM
by eric_b_85
I upgraded from 1.5 to 1.6.2.7 (CentOS 7 Linux server). Everything seemed to go smoothly.
I can see my workstations in the console. The clients are updating gradually and have access to the repository.
What I don't understand is the issue on my management workstation, because I can access my private repository via the console but not on the workstation itself.
If I ask it to update the software inventory, it returns "0 packages in the repository, the system is up to date".
Re: Empty Depot
Published: November 17, 2018 - 1:17 PM
by sfonteneau
Can you do a:
wapt-get update -ldebug
Re: Empty Depot
Published: November 17, 2018 - 6:36 PM
by eric_b_85
C:\Users\administrator.INCAF85>wapt-get update -ldebug
2018-11-17 18:32:33,641 DEBUG Default encoding: ascii
2018-11-17 18:32:33,641 DEBUG Setting encoding for stdout and stderr to cp850
2018-11-17 18:32:33,653 DEBUG Python path ['C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\python27.zip', 'C:\\Program Files (x86)\\wapt\\DLLs', 'C:\\Program Files (x86)\\wapt\\lib
', 'C:\\Program Files (x86)\\wapt\\lib\\plat-win', 'C:\\Program Files (x86)\\wapt\\lib\\lib-tk', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages', 'C:\\Program Files (x86)\\wapt\\lib\\site-packa
ges\\pywin32-223-py2.7-win32.egg']
2018-11-17 18:32:33,654 INFO Using local waptservice configuration C:\Program Files (x86)\wapt\wapt-get.ini
2018-11-17 18:32:33,654 DEBUG Config file: C:\Program Files (x86)\wapt\wapt-get.ini
2018-11-17 18:32:33,660 DEBUG Thread 4100 is connecting to wapt db
2018-11-17 18:32:33,661 DEBUG Thread 4100 is connecting to wapt db
2018-11-17 18:32:33,664 DEBUG DB Start transaction
2018-11-17 18:32:33,664 DEBUG DB commit
2018-11-17 18:32:33,736 INFO User Groups:[]
2018-11-17 18:32:33,736 DEBUG WAPT base directory: C:\Program Files (x86)\wapt
2018-11-17 18:32:33,736 DEBUG Package cache dir: C:\Program Files (x86)\wapt\cache
2018-11-17 18:32:33,737 DEBUG WAPT DB Structure version;: 20180917
2018-11-17 18:32:33,737 DEBUG Checking if old install in progress
2018-11-17 18:32:33,927 DEBUG DB Start transaction
2018-11-17 18:32:33,927 DEBUG reset stalled install_status in database
2018-11-17 18:32:33,928 INFO Status:
2018-11-17 18:32:33,930 DEBUG DB commit
Update package list
2018-11-17 18:32:33,943 DEBUG DB Start transaction
2018-11-17 18:32:33,974 DEBUG Remove unknown repositories from packages table and params ("wapt","wapt-host")
2018-11-17 18:32:33,976 INFO Getting packages from https://wapt.incaf85.flc/wapt
2018-11-17 18:32:33,976 DEBUG Check last-modified header for wapt to avoid unnecessary update
2018-11-17 18:32:33,976 DEBUG Checking availability of https://wapt.incaf85.flc/wapt/Packages
2018-11-17 18:32:33,983 DEBUG Starting new HTTPS connection (1): wapt.incaf85.flc
2018-11-17 18:32:33,990 DEBUG https://wapt.incaf85.flc:443 "HEAD /wapt/Packages HTTP/1.1" 200 0
2018-11-17 18:32:33,990 INFO Index from wapt has not been updated (last update 2018-11-12T10:34:31), skipping update
2018-11-17 18:32:33,992 INFO Getting packages from https://wapt.incaf85.flc/wapt-host
2018-11-17 18:32:33,992 DEBUG need_update: no last_modified date provided, update is needed
2018-11-17 18:32:33,993 DEBUG Read remote Packages index file https://wapt.incaf85.flc/wapt-host/Packages
2018-11-17 18:32:33,993 DEBUG Trying to get host package for EF364D56-04C7-FC33-82CF-3658A0C765C8 at https://wapt.incaf85.flc/wapt-host/EF36 ... 765C8.wapt
2018-11-17 18:32:33,996 DEBUG Starting new HTTPS connection (1): wapt.incaf85.flc
2018-11-17 18:32:34,002 DEBUG https://wapt.incaf85.flc:443 "GET /wapt-host/EF364D56-04C7-FC33-82CF-3658A0C765C8.wapt HTTP/1.1" 200 2716
2018-11-17 18:32:34,016 DEBUG Stores cert chain check in cache
2018-11-17 18:32:34,016 INFO Unable to update repository status of https://wapt.incaf85.flc/wapt-host, error None of certificates ("srvwapt","srvwapt") are trusted.
2018-11-17 18:32:34,023 DEBUG Error at DB exit None of certificates ("srvwapt","srvwapt") are trusted., rollbacking
[' File "C:\\Program Files (x86)\\wapt\\common.py", line 3804, in _update_db\n last_modified = repo.packages_date()\n', ' File "C:\\Program Files (x86)\\wapt\\waptpackage.py", line 2101, in packages_date\n self._load_packa
ges_index()\n', ' File "C:\\Program Files (x86)\\wapt\\common.py", line 2254, in _load_packages_index\n package.check_control_signature(self.cabundle,signers_bundle = signers_bundle)\n', ' File "C:\\Program Files (x86)\\wapt\
\waptpackage.py", line 1265, in check_control_signature\n issued_by = trusted_bundle.check_certificates_chain(certs)[-1]\n', ' File "C:\\Program Files (x86)\\wapt\\waptcrypto.py", line 541, in check_certificates_chain\n rai
se EWaptCertificateUnknownIssuer(reason)\n']
2018-11-17 18:32:34,023 CRITICAL Error getting Packages index from https://wapt.incaf85.flc/wapt-host : EWaptCertificateUnknownIssuer: None of certificates ("srvwapt","srvwapt") are trusted.
2018-11-17 18:32:34,025 DEBUG DB commit
2018-11-17 18:32:34,095 DEBUG Checking availability of host packages "[]"
2018-11-17 18:32:34,096 DEBUG store status in DB
2018-11-17 18:32:34,098 DEBUG DB Start transaction
2018-11-17 18:32:34,098 DEBUG DB commit
Total packages: 0
Added packages:
Removed packages:
Discarded packages count: 235
Pending operations:
upgrade:
additional:
install:
remove:
Repositories URL:
