Page 1 of 1
Installing a package
Published: November 30, 2018 - 11:50 AM
by vandatt
I'm setting up a WAPT server and I want to deploy software that isn't included in the WAPT library. I've followed the technical documentation and used PyScript, but when I right-click on "i-build-upload", an error appears in the waptutils.py file on the line "import custom_zip as zipfile". However, I've verified that the module is present in C:\python34\Lib.
Do you know of a solution to this problem?
Thank you in advance.
Re: Installing a package
Published: November 30, 2018 - 1:59 PM
by sfonteneau
it seems you don't have the correct Python environment in PyScripter. You mentioned
... Could you check the registered and used version in PyScripter? (see image)
