Page 1 of 1
[SOLVED] Delete multiple files
Published: Dec 3, 2018 - 3:02 PM
by lowix
Hello community!
I'm trying to delete multiple files based on their extension using the "remove_file" function, and I was wondering if it's possible to use a wildcard character like this:
remove_file(r'C:\Users\Public\Desktop\*.lnk')
Thank you in advance for your reply ;)
Re: Question about remove_file
Published: Dec 3, 2018 - 3:10 PM
by htouvet
not directly...
import glob
    for filename in glob.glob(r'C:\Users\Public\Desktop\*.lnk'):
        delete_file(filename)
Published: Dec 3, 2018 - 3:59 PM
by lowix
htouvet wrote: ↑Dec 3, 2018 - 3:10 PM not directly...
import glob
tremendous !
Published: Dec 3, 2018 - 4:20 PM
by lowix
import glob
However, unless I'm mistaken, it's a remove_file and not a delete_file
THANKS
