GPO application problem
Published: Dec 12, 2018 - 11:14
and thank you again for your forum.
I'm still stuck on applying GPOs via the samba4 (4.8.3) AD man page.
The GPOs are applied once when the client joins the domain, but on subsequent startups, no GPOs are applied. I really don't understand why.
If I force the GPOs (gpupdate /force), there are no problems, but at startup, no GPOs are applied.
I'm considering the DNS; I'm using Samba's internal DNS, and in my logs before the GPOs are applied, I get a dynamic name update error. Do you think this could be the cause?
Is it absolutely necessary to install BIND for it to work correctly?
Thank you for your suggestions.
