Page 1 of 1
Unable to install a package
Published: January 15, 2019 - 2:43 PM
by Tombru
I'm new to this forum. Happy New Year 2019.
Installing version 1.3 of the server and client on Windows 7 worked perfectly. However, the packages are now designed for newer versions.
I couldn't update the server from 1.3 to 1.6, so I had to reinstall everything and redeploy the agent using my Kaspersky antivirus.
My setup is as follows:
Wapt Server version 1.6.2.7 on Windows Server 2012 R2.
Client PCs run on Windows 7, but primarily on Windows 10 version 1709.
I've added Wapt-related exceptions to my Kaspersky Central Console.
The Wapt agent on my PC is working; I can see it in my console.
When I try to install a Firefox package (or any other package), I get a message from WaptConsole indicating 0 actions launched, 1 error, 0 skipped, and 0 server errors. A small clock icon appears next to my PC's inventory. Nothing happens after that.
Any idea what the problem might be?
Re: Unable to install a package
Published: January 16, 2019 - 1:56 PM
by agauvrit
there's a 99% chance that your computers' clocks are incorrect and therefore not properly connected to the WAPT server.
Alexandre
Published: January 17, 2019 - 08:15
by Tombru
Thank you for your reply, but the PCs are synchronized with the server, so their clocks are all correct. This morning I just saw that it connected when I logged in at 7:46 AM.
I had no problems with version 1.3.
I will test the Windows 7 machines and keep you informed.
Regards
Published: January 18, 2019 - 3:53 PM
by Tombru
I just ran a test on a Windows 7 machine where version 1.3 worked perfectly. I'm getting the same result. So, there's a general problem somewhere.
Any ideas?
Thanks in advance.
Regards
Published: January 19, 2019 - 4:22 PM
by sfonteneau
There is a huge difference between version 1.3 and 1.5.
How did you perform the 1.3 to 1.5 update? At a minimum? Did you regenerate your keys correctly?
This type of problem mainly occurs when the request is incorrectly signed
The most frequent reasons for refusal:
- Wrong key
- Time difference between the workstation with the console (the one that signed the action) and the remote workstation (maximum 5-minute difference)
If that still doesn't work, start the service on the remote machine with:
C:\Program Files (x86)\wapt\runwaptservice.bat -ldebug
Published: January 21, 2019 - 4:28 PM
by Tombru
the update wasn't working. So, I uninstalled version 1.3 and installed version 1.6, as mentioned above.
I reused the existing certificate; perhaps that's where the problem lies.
How do I create a valid certificate? I suppose I should delete the old ones and create new ones?
However, will I need to recreate the packages I created with the old certificate so they are re-signed by the new one?
Also, it asks me to verify the key when I update a machine. Is it possible to prevent this verification?
Oh yes, do I need to update the agent on the workstations after re-creating the certificates?
Thank you for your help.
Published: January 21, 2019 - 5:36 PM
by sfonteneau
Published: January 22, 2019 - 8:05 AM
by Tombru
I had to do a complete reinstallation because I couldn't finalize the upgrade from version 1.3 to 1.6 due to an agent version issue. Even after updating to 1.6, it still didn't work. I hadn't found any concrete answers to this problem.
So, I'm going to start from scratch with the certificate configuration and re-sign the packages.
I'll keep you posted. Thank you very much.
Best regards
Published: January 22, 2019 - 12:29
by Tombru
I just repeated the process: certificates, resigned packages, and updated the agent.
I tested it on my Windows 10 PC and a Windows 7 machine in my network after updating the agent, and it works.
It also works on a newly installed Windows 10 laptop.
I am currently deploying the updated and functional agent across my entire network.
The ticket is therefore resolved.
Thank you very much to the team for the successful assistance.
Best regards
