Page 1 of 1
Error: Agent disconnected, but status is OK
Published: January 18, 2019 - 11:25 AM
by nemesis2o0o
Hello, for the past week my agents have been showing as disconnected in the reachable column, but their status is OK.
Do you have any idea what the problem might be, knowing that I have one workstation that is working correctly?
Thank you for your help.
Re: Agent disconnected error but status ok
Published: January 18, 2019 - 2:08 PM
by dcardon
Hello nemesis2o0o,
nemesis2o0o wrote: ↑January 18, 2019 - 11:25 AM Hello, for the past week my agents have been showing as disconnected in the reachable column, but their status is OK.
Do you have any idea what the problem might be, knowing that I have one workstation that is OK?
Which version of WAPT, which server OS, which client OS? cf. viewtopic.php?f=13&t=887
Published: January 18, 2019 - 2:17 PM
by nemesis2o0o
- Installed WAPT version (1.6)
- Server OS (Linux Debian 9)
- Administration/package creation machine OS (Windows 10)
Published: January 21, 2019 - 11:29 PM
by dcardon
Good evening Nemesis2o0o,
nemesis2o0o wrote: ↑Jan 18, 2019 - 2:17 PM - WAPT version installed (1.6)
The most likely problem is a time difference. By default, WAPT 1.6 allows a maximum time difference of 5 minutes to prevent replay attacks.
The OK status of machines corresponds to the state they reported during their last inventory.
The connected state corresponds to the successful establishment of the websocket connection from the workstation to the server.
Published: January 22, 2019 - 1:32 PM
by nemesis2o0o
Thank you for your feedback, but I've double-checked and the time is correct.
However, I managed to fix the problem by reinstalling the wapt_agent package.
wapt-upgrade was present but wouldn't install.
Do you have any ideas?
Thank you.
