Package with just a link
Published: March 6, 2019 - 09:33
I want to create a package that simply creates a link on the user's desktop.
It seemed quite trivial to me, with examples all over the documentation or on the internet, and yet I can't manage it.
Here is my Python code:
And with each attempt to execute it, I get:
Could someone tell me what's wrong?
THANKS
print('installing EDITML')
def session_setup():
create_user_desktop_shortcut(r'Editer une liste de distribution',target='%systemroot%\system32\rundll32.exe dsquery.dll,OpenQueryWindow')
Ligne de Commande : session-setup "c:\waptdev\ADV-EDITML-wapt\WAPT\.."
Configuring c:\waptdev\ADV-EDITML-wapt ...
2019-03-06 09:27:59,496 CRITICAL Fatal error in session_setup function: -2147024809 : Paramètre incorrect.:
File "C:\Program Files (x86)\wapt\waptpackage.py", line 1843, in call_setup_hook
hookdata = hook_func()
File "c:\waptdev\ADV-EDITML-wapt\setup.py", line 9, in session_setup
File "C:\Program Files (x86)\wapt\setuphelpers.py", line 472, in create_user_desktop_shortcut
create_shortcut(sc_path,target,arguments,wDir,icon)
File "C:\Program Files (x86)\wapt\setuphelpers.py", line 410, in create_shortcut
winshell.CreateShortcut(path,target,arguments,wDir,(icon,0),'')
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 887, in CreateShortcut
lnk = shortcut (Target)
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 507, in shortcut
return Shortcut.from_target (source)
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 417, in from_target
**kwargs
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 391, in __init__
setattr (self, k, v)
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 456, in _set_path
self._shell_link.SetPath (path)
com_error: (-2147024809, 'Param\xe8tre incorrect.', None, None)
Done
>>> THANKS
