Page 1 of 1
Waptagent deployment - non-reachable client
Published: March 8, 2019 - 12:12
by lazy
- Installed WAPT version 1.7.3.5
- Server OS: Debian 9.7
- Operating system of the administration/package creation machine: Windows Server 2012 R2
I set up the Wapt server in my establishments 2-3 weeks ago. Everything works well except for the deployment of the agent on client workstations.
When I download and install the agent via the executable on a client machine, I have no problem. But when I try to do it via GPO, scheduled task, or simple command line, the client machine appears correctly in the WAPT console, but it is not accessible (no green indicator light icon in the "Reachable" column).
I tried adding some extra details like the server address, but it didn't change anything...
waptdeploy.exe --hash=monHash --minversion=1.7.3.5 --waptsetupurl=http://monagent.exe --setupargs="/wapt_server https://mon.server" --wait=15
When using the command line directly, there are no error messages in the terminal. I have no idea.
Thank you in advance for your help
Re: Waptagent deployment - non-reachable client
Published: March 11, 2019 - 09:46
by agauvrit
If the green icon does not appear, it could be a problem with the 'http_proxy' environment variable, an issue encountered by a WAPT Enterprise client.
Another possibility is that the computer's clock is not synchronized with the server's.
Re: Waptagent deployment - no green icon on the Wapt console
Published: August 27, 2019 - 2:56 PM
by CHISFE
- WAPT version installed: 1.7.3.5
- Server OS: Windows 7 Pro
- Client machine OS: Windows 7 Pro 32-bit
Hello everyone,
on my WAPT server with the latest version, I have all the computers on the console, but on some workstations, there's no green "reachable" icon. I can't figure out where the problem is coming from. The client workstations are set to the same time as the WAPT server. Can you help me, please?
A screenshot is attached.
Thank you in advance, and a big thank you again to the entire WAPT team.
CHISFE
