[SOLVED] Problem installing Waptagent
Published: March 21, 2019 - 11:20
the software installation and deployment are OK.
I'm having a small problem deploying the agent. When I deploy it manually or via the command `waptdeploy.exe --hash=...`, a pop-up appears asking for the wapt account password to add the computers to the database.
This is causing a problem for deployment via script or GPO.
How can I remove this authentication request so I can script and install via GPO using waptagent?
Thank you in advance for your answers.
