Customize the console
Published: April 17, 2019 - 4:39 AM
is it possible to add custom actions to the console menus?
I'm thinking of a shutdown or restart command for selected machines (similar to "Start with WakeOnLine," for example).
And if so, what precautions should I take to avoid having to redo everything in case of a WAPT version update?
Thank you.
Thank you.
