Page 1 of 1
XMind and Bonjour
Published: May 2, 2019 - 09:12
by hasop
We have updated the package offered for Xmind to the latest version and have integrated a preference file designed to disable the startup warning message for installing the Bonjour network sharing software (see http://support.xmind.net/customer/porta ... stallation).
On older versions, this seemed to work.
However, now, on new installations of the package, we are again getting the Bonjour warning message ("Do you want to install the Bonjour service..."). Since users do not have administrator rights on their machines, they cannot click OK to complete the installation.
Have you encountered this problem and found a workaround?
Thank you
Re: XMind and Hello
Published: May 9, 2019 - 7:28 PM
by dcardon
Hello Hasop,
hasop wrote: ↑May 2, 2019 - 9:12 AM We have updated the package offered for Xmind to the latest version and have integrated a preference file designed to disable the startup warning message for installing the Bonjour network sharing software (see http://support.xmind.net/customer/porta ... stallation).
However, now, on new installations of the package, we are again getting the Bonjour warning message ("Do you want to install the Bonjour service..."). Since users do not have admin rights on their machines, they cannot click OK to complete the installation.
The best way is to make the change graphically as an administrator on a machine with Xmind installed and then diff the Xmind profile directory (personal profile and ProgramData directory). You can use the tis-regshot package to diff the directory or registry.
