Page 1 of 1
[RESOLVED] Database is locked
Published: May 7, 2019 - 2:38 PM
by gaelds
since the update to version 1.7.3.5, I've had about ten cases of machines failing to update, displaying the message "OperationalError: database is locked". What should be done in this situation? I manually uninstalled and reinstalled the client, and it's working again on some machines, but others are still stuck.
[upload image]
Re: Database is locked
Published: May 9, 2019 - 6:49 PM
by dcardon
Hello Gaelds,
gaelds wrote: ↑May 7, 2019 - 2:38 PM Hello,
Since the update to version 1.7.3.5, I've had about ten cases of machines no longer updating, displaying the message "OperationalError: database is locked". What should be done in this case? I manually uninstalled/reinstalled the client and it works again on some machines, but others are still stuck.
This issue has been addressed in version 1.7.4. It should be released tomorrow for the webinar hosted by Simon in the early afternoon. By the way, if you haven't already registered, I encourage you to do so quickly at the following address: https://www.tranquil.it/evenement/webin ... e-de-wapt/ !
Published: May 13, 2019 - 3:26 PM
by gaelds
Okay, thanks, I'll wait until version 1.7.4 is available then.
Published: May 14, 2019 - 12:46
by htouvet
