Installation session open
Published: July 29, 2019 - 1:43 PM
I have a SIGAL software application whose updates can only be installed while the user is logged in.
Aside from using "def session_setup():" which would install the update every time a new user logs in, do you see a way to install it while the user is logged in, so that it only runs once?
Thank you.
Debian 9.9 server
, WAPT 1.6.2.7,
package creation workstation under Windows 10.
Thank you.
Debian 9.9 server
, WAPT 1.6.2.7,
