WAPT-Exit
Published: July 30, 2019 - 4:36 PM
- Installed WAPT version 1.7.4.6143 Enterprise
- Debian Stretch server OS
- Operating system of the administration/package creation machine (Windows 10)
I just realized there's been a problem for the last 1 or 2 weeks: wapt-exit isn't working on our machines.
During shutdown or reboot, the WAPT-exit window appears very quickly and closes immediately, even though there are packages waiting to be installed.
I have not made any modifications that could prevent it from working properly.
I tried forcing an installation and restarting the machine; the wapt-exit command executed correctly
Here is the wapt-get.ini file for the wapt-exit part:
I don't see anything in the logs.
Speaking of logs, I have a colleague who can't connect to the console even though the connection to AD works; he's the only one who won't work. I can't find any logs that can point me towards the problem.
PS: I don't know if I should use the forum or open a support ticket.
Thank you
max_gpo_script_wait= 180
pre_shutdown_timeout= 180
hiberboot_enabled= 0
notify_user = 0
allow_cancel_upgrade = 0Speaking of logs, I have a colleague who can't connect to the console even though the connection to AD works; he's the only one who won't work. I can't find any logs that can point me towards the problem.
Thank you
