Page 1 of 1
Uninstallation key
Published: August 2, 2019 - 2:43 PM
by had69
I'm having trouble retrieving my uninstallation key.
When I type the command `wapt-get list-registry "mysoftware"`, it's not listed.
I think this is because my software installs in "C:\Users\MyUser\AppData\Local\Programs" and not in Program Files.
So I'm really stuck. :)
Thanks for your help.
Re: Uninstallation key
Published: August 6, 2019 - 10:18
by jpele
Indeed, since the registry keys are not registered in the correct location, you cannot find the application using "list-registry".
Could you please tell me the name of the software? There are a few techniques to force the installation in "ALLUSERS".
Jimmy
Published: August 7, 2019 - 11:03
by had69
The software in question is MonSisra (a secure messaging tool for healthcare professionals).
Here is the link:
https://www.sante-ra.fr/services/monsisra/
Sincerely
Published: August 7, 2019 - 3:11 PM
by jpele
I just tested the command: monsisra2-setup-latest.exe /NCRC /S /D="C:\Program Files (x86)\monsisra2"
Unfortunately, it doesn't install the software in the desired directory.
I suggest you perform a portable (manual) installation by retrieving the files from: "C:\Users\user\AppData\Local\Programs\monsisraapp"
By creating the necessary directories and shortcuts, you should be able to manage.
Jimmy
Published: August 7, 2019 - 8:26 PM
by vcardon
A "secure" email program that only installs in directories where users have write access doesn't exactly inspire confidence in the software.
I would also advise you to contact the publisher to see if they have an installer that silently installs the program in "normal" directories, which can then be secured with SRP or AppLocker.
The user directory is definitely not a safe place to store executables.
Vincent
