Page 1 of 1
The downloaded flashplayer file is corrupted; the MD5 checksum does not match.
Published: August 20, 2019 - 11:01
by GuillaumeG
After the WAPT server was down for 15 days, when downloading packages from the official repository,
the following message appears: "The downloaded Flash Player file is corrupted; the MD5 checksum does not match."
No changes have been made to the settings.
Thank you for your help.
Re: The downloaded flashplayer file is corrupted, the MD5 checksum does not match.
Published: August 20, 2019 - 1:32 PM
by sfonteneau
are you using version 1.7 of Wapt?
Published: August 21, 2019 - 08:12
by GuillaumeG
Published: August 21, 2019 - 10:33
by sfonteneau
Version 1.6 of wapt had a problem that has been fixed since version 1.7.
After an update, the problem should be resolved.
