Error installing package tis-chrome
Published: August 22, 2019 - 4:53 PM
I had installed Chrome version 74 using the TIS-Chrome package. When downloading and deploying the latest version (76.0), I get an error message every time
Can you help me please? Even if I force the installation, uninstall via the console, and reinstall, it doesn't work. The only thing that works is uninstalling it physically on the computer, and then the installation works after shutting down.
THANKS
THANKS
Installing there-chrome
Installing there-chrome(=76.0.3809.87-3)
installing tis-chrome
File C:\Program Files (x86)\Google\Chrome\Application\chrome.exe version is : 76.0.3809.100
Paquet version is : 76.0.3809.87
------ SKIP ------
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1587, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 551, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1009, in _run
Exception: Erreur lors de l'installation de [u'there-chrome']: erreurs dans les paquets [[PackageRequest(package=u'there-chrome',architectures=[u'x64'],locales=['fr'],maturities=[u'PROD'],min_os_version=Version('10.0.15063'),max_os_version=Version('10.0.15063')), PackageEntry(u'there-chrome',u'76.0.3809.87-3' architecture=u'x64'), u'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4803, in install\n force=force\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3901, in install_wapt\n raise e\nEWaptException: The uninstall key: {86B1D736-F1F4-3367-9B39-C2E176B68239} has not been found in system registry after software installation.\n']]
self._run()
