Page 1 of 2
Review - Following update 1.7.4.6155, there are package management issues
Published: September 5, 2019 - 10:33 AM
by avondra
Wapt version 1.7.4.6155
Server OS: CentOS 7.6
Admin OS: Windows 10
Following my MD5 verification problem, I upgraded Wapt from 1.6.7 to the latest version 1.7.4. I no longer have the error, but package installations and updates no longer work. I don't get an error message, but there is no longer any interaction with clients.
Can you shed some light on this new malfunction? It's also very urgent because I need to deploy a softphone by tomorrow evening...
Thank you for your help.
Re: Criticism - Following update 1.7.4.6155, package management problems
Published: September 5, 2019 - 10:47 AM
by avondra
Continuation,
Little info, a strange message in debug mode when I launch the installation on a client which seems a little contradictory:
DEBUG:urllib3.connectionpool:https://unc-srv-susi.cfu.local:443 "GET /wapt-host/4C4C4544-0056-5A10-8031-CAC04F4D3432.wapt HTTP/1.1" 200 2851
DEBUG:root:ERROR for c:\private\wapt-private.pem: Unable to load key c:\private\wapt-private.pem
DEBUG:root:SUCCESS key c:\private\wapt-private.pem match certificate c:\private\wapt-private.crt
{"msg":"1 actions launched, 0 errors, 0 skipped, 0 server errors","success":true,"request_time":null,"result":[]}
Published: September 5, 2019 - 4:54 PM
by avondra
Can no one give me feedback?
Thanks
Published: September 6, 2019 - 10:46 AM
by avondra
Okay, I'm still answering myself... by adding to the discussion.
It seems to be an SSL certificate issue because when I check the certificate or when I query the Wapt server using the wapt-get command, I get an error: clients cannot communicate with the server, hence the inability to perform updates:
TypeError: argument of type 'NoneType' is not iterable.
It looks like a python bug, I'm in 2.7 is this a possible solution and do you have a workaround
C:\wapt>wapt-get.exe register
Using config file: C:\wapt\wapt-get.ini
Registering host against server: https://unc-srv-susi.cfu.local
System Power Controls
FATAL ERROR: SSLError: HTTPSConnectionPool(host='unc-srv-susi.cfu.local', port=443): Max retries exceeded with url: /add_host (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')],)",),))
C:\wapt>wapt-get enable-check-certificate
Server certificate: C:\wapt\ssl\server\unc-srv-susi.cfu.local.crt
FATAL ERROR: TypeError: argument of type 'NoneType' is not iterable
Published: September 6, 2019 - 5:13 PM
by htouvet
Are you using a self-signed certificate for the nginx server on the server side?
If so, is this certificate identical to the one in C:\wapt\ssl\server\unc-srv-susi.cfu.local.crt?
If this certificate is signed by a CA, does the server-side PEM file contain the entire certificate chain (intermediate and root CAs)?
Published: September 6, 2019 - 6:10 PM
by avondra
Yes, I'm using a self-signed certificate for the nginx server on the server side.
The certificate is identical to the one in C:\wapt\ssl\server\unc-srv-susi.cfu.local.crt.
The certificates are identical, but I'm getting these errors and nothing happens in the waptconsole when I update the clients.
Published: September 9, 2019 - 12:09 PM
by avondra
Still no response...
I've also noticed errors when adding new hosts:
2019/09/09 11:57:21 [error] 1530#0: *159902 open() "/var/www/html/wapt-host/4C4C4544-0031-3310-8051-B4C04F324732.wapt" failed (2: No such file or directory), client: 192.203.100.44, server: xxxxxxxxxx, request: "GET /wapt-host/4C4C4544-0031-3310-8051-B4C04F324732.wapt HTTP/1.1", host: "xxxxxxxxxx"
I have to create this file manually, which isn't normal; since the version upgrade, there have been problems They're piling up...
Help!!
Published: September 9, 2019 - 12:45 PM
by avondra
From my research, it seems to be a problem with the private key, which isn't being accepted when I push updates. However, I've checked the interface and everything looks OK, but I saw this alert in the console debug:
EWaptCertificateUntrustedIssuer: None of certificates ("wapt-private","wapt-private") are trusted.
What can I do, since the installation via WAPT Self-Service works on the client?
Published: September 11, 2019 - 11:33
by avondra
I don't understand this deafening silence...
Is there no developer who might have an idea to help me track down this bug?
I've already uninstalled and reinstalled my console, recreated my keys, but nothing works.
I've never had any problems with the various WAPT version upgrades, and I still consider it an essential tool.
Do I have to resign myself to reinstalling my server from scratch and losing all my installation history?
Published: September 11, 2019 - 5:04 PM
by sfonteneau
Good morning
The easiest way to help us is by running a few commands (you've already done some of them), can you send us the result?
wapt-get update -f
wapt-get register
The contents of your agent's wapt-get.ini file
The console's waptconsole.ini (%localappdata%\waptconsole\waptconsole.ini)
Can you also run this (starts the debug mode agent):
"c:\Program Files (x86)\wapt\runwaptservice.bat" -ldebug
Then perform actions using the console and send us back the result from the agent in debug mode?
The files:
  • C:\Program Files (x86)\wapt\ssl\*.crt
  • C:\Program Files (x86)\wapt\ssl\server\*.crt
  • C:\Program Files (x86)\wapt\private\*.crt
For the server, this file:
/opt/wapt/waptserver/ssl/cert.pem
Also the crt file indicated in the waptconsole.ini file (%localappdata%\waptconsole\waptconsole.ini)
Also check the time:
  • From the post that has the wapconsole
  • From agent Wapt
  • And from the Wapt server
On Windows computers you can check the time like this:
waptpython
import datetime
datetime.datetime.utcnow()
Yes, because time zone differences, daylight saving time, etc., it's complicated...
