Page 1 of 1
Problem updating from Debian 1.5 to 1.7 9
Published: September 10, 2019 - 3:48 PM
by Chuge
I am encountering a problem when I try to update the WAPT 1.5 community server installed on a Debian 9 system to version 1.7
I'm getting an error message regarding the GPG key
GPG error: https://wapt.tranquil.it/debian/wapt-1.7 stretch InRelease: The following signatures were invalid: EXPKEYSIG 58F751F8EE23241E Tranquil IT Systems <contact@tranquil.it>
W: The repository 'https://wapt.tranquil.it/debian/wapt-1.7 stretch InRelease' is not signed.
Do you have a solution?
Regards
Re: Problem updating from 1.5 to 1.7 Debian 9
Published: September 11, 2019 - 1:01 PM
by Chuge
Using this command, I no longer get the error message
curl -k https://wapt.tranquil.it/debian/wapt-1.7/dists/stretch/InRelease | gpg --keyring /etc/apt/trusted.gpg --verify
the result of this command without the -k
curl
https://wapt.tranquil.it/debian/wapt-1. ... /InRelease | gpg --keyring /etc/apt/trusted.gpg --verify
Total
Received
https://curl.haxx.se/docs/sslcerts.html%
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
gpg: verify signatures failed: Unknown system error
gpg: no valid OpenPGP data found.
gpg: the signature could not be verified.
Regards
Published: September 11, 2019 - 2:20 PM
by Chuge
Upgrade to 1.7 -> OK
But there's still an error message:
wget -O - https://wapt.tranquil.it/debian/tiswapt-pub.gpg | apt-key add -
--2019-09-11 13:18:41-- https://wapt.tranquil.it/debian/tiswapt-pub.gpg
Resolving wapt.tranquil.it (wapt.tranquil.it)... 185.16.48.72
Connecting to wapt.tranquil.it (wapt.tranquil.it)|185.16.48.72|:443... connected.
ERROR: The certificate of ‘wapt.tranquil.it’ is not trusted.
ERROR: The certificate of ‘wapt.tranquil.it’ hasn't got a known issuer.
The certificate's owner does not match hostname ‘wapt.tranquil.it’
Published: September 15, 2019 - 7:48 PM
by sfonteneau
It was a temporary issue on our repo.
It should be working now!
