Page 1 of 1
[SOLVED] Selecting multiple machines in the WAPT console
Published: September 16, 2019 - 4:31 PM
by qi-support
We are using WAPT with console version 1.6.2.7. The OS is Windows Server 2008 R2.
Deployment works perfectly when a single machine is selected.
Deployment does not work if multiple machines are selected because the "Edit Machine" function is grayed out.
Do you have a solution?
Best regards,
ALN
Re: Selecting multiple machines in the WAPT console
Published: September 16, 2019 - 6:14 PM
by sfonteneau
you must use the "add a dependency" button,
then "check for updates" or directly "Start the installations".
Published: September 24, 2019 - 10:37 AM
by qi-support
I will be on site this week and will keep you updated on the situation.
Thank you for your feedback.
ALN.
