Page 1 of 1
error at the end of a build
Published: September 24, 2019 - 2:20 PM
by tice
Hello, using the package creation wizard, I select my .exe file, click Continue, PyScripter opens, I build it, and the package is created. So far, so good.
Then this error appears:
Done Uploading c:\waptdev\ray-CrossPC_22.0.2.0-1_all.wapt
FATAL ERROR: HTTPError: 500 Server Error: for url:
https://172.23.197.239/api/v3/upload_packages
Exit code: 3
What does this mean and how can I fix it?
Thank you
Re: Error at the end of a build
Published: September 24, 2019 - 3:34 PM
by tice
To elaborate, in the console/tools/preferences, when I check "Verify the server's HTTPS certificate", it shows an access error on both the repository and the server: 14090086:SSLRoutines:SSL3-get-...(out of windows)
Published: September 25, 2019 - 00:11
by sfonteneau
Error 500 is a broad error.
Is it a large packet?
Be careful with the HTTPS certificate verification in the console!
You should only enable it if your configuration is correct (server and certificate bundle!).
Published: September 26, 2019 - 09:48
by tice
- 10 MB
- how to know if the configuration is correct?
Published: September 26, 2019 - 11:15 AM
by sfonteneau
Hmm... could you give us the Wapt server logs?
Published: September 26, 2019 - 11:55 AM
by tice
No, I can no longer launch the console; I get
the same message as mentioned above after checking the "verify the server's HTTPS certificate" option.
Published: September 26, 2019 - 11:57 AM
by sfonteneau
Did you uncheck the box?
Published: September 26, 2019 - 12:17 PM
by tice
It was complicated not being able to launch the console ^^
.ini file modified, console launched, where can I find the logs please?
