Page 1 of 1
[RESOLVED] Klavaro Package
Published: October 9, 2019 - 9:51 AM
by olaplanche
I've created a package for the latest version of Klavaro 3.09.
However, the application seems to have issues under Windows 10 and requires running in Windows 7 compatibility mode (based on my tests). I'd like to know if it's possible to manage this directly within the package, either by creating a new shortcut for all users with Windows 7 compatibility mode, or through session setup on the application binary?
Thank you.
Re: Klavaro package
Published: October 9, 2019 - 11:47 AM
by Yoann
An application's compatibility mode can be defined via the registry.
- For all users: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
- For the current user: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
Each key corresponds to an application, with the executable's location as its name and the Windows version as a string value (REG_SZ).
- Windows Vista: ~ VISTARTM
- Windows Vista (Service Pack 1): ~ VISTASP1
- Windows Vista (Service Pack 2): ~ VISTASP2
- Windows 7: ~ WIN7RTM
- Windows 8: ~ WIN8RTM
In the install , you would simply need to use the registry_setstring to add a value to the registry.
Regards.
Re: [RESOLVED] Klavaro Package
Published: October 10, 2019 - 11:03 AM
by olaplanche
Thank you! Compatibility issue solved!
Here is the final code:
uninstallkey = ['{F29D32EB-AC0D-4D2E-9A75-90A6C626CE6E}_is1']
print('installing wapt-klavaro')
install_exe_if_needed("klavaro-3.09-win-setup.exe",'/VERYSILENT /SUPPRESSMSGBOXES /NORESTART',key='',min_version='3.09')
if windows_version()>=Version('10.0'):
registry_set(HKEY_LOCAL_MACHINE,r'SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\AppCompatFlags\\Layers',r'C:\Program Files (x86)\Klavaro\bin\klavaro.exe',r'~ WIN7RTM FaultTolerantHeap',type=REG_SZ)
remove_desktop_shortcut('Klavaro.lnk')
uninstallkey.remove('{F29D32EB-AC0D-4D2E-9A75-90A6C626CE6E}_is1')
run(r'"%s\Klavaro\unins000.exe" /verysilent' % programfiles32)
remove_tree(r'%s\Klavaro' % programfiles32)
Published: October 22, 2020 - 3:55 PM
by jpele
The package has been updated on the Store with compatibility mode for Windows 10.
Regards,
Jimmy
