Page 1 of 1
[SOLVED] Silent Installation of WAPT Console
Published: November 7, 2019 - 4:08 PM
by Gaetan
I'm planning to create an installation package for the WAPT console and would like to know if a silent installation is possible.
Thank you
Re: Silent Installation of WAPT Console
Published: November 8, 2019 - 3:53 PM
by vcardon
Hi Gaëtan,
You don't need a package to deploy the console ;)
. The console comes standard with every WAPT agent.
Instead, launch the WAPTtray (Windows key => wapttray.exe) and you can right-click => Launch WAPT console. The console login screen will open.
How it works:
If the user has a password to access the console but the package signing key is not accessible, then only the inventory will be displayed.
If the user has a password to access the console AND access to the signing key, then they will have full access.
Note, however, that this behavior could change in the future and become more like what you expected. Have ;)
a good weekend.
Vincent
Published: November 8, 2019 - 4:54 PM
by Gaetan
Hi Vincent,
thanks for the quick reply. I'll pass the information on to everyone.
Have a good weekend.
