Page 1 of 1
Using "External Tools" (or plugins)
Published: November 27, 2019 - 6:21 PM
by Patrice_minagri
Is the "External Tools" (or plugins) function working in the WAPT console?
I've tried two things:
Name - Executable - Arguments
Explorer - explorer.exe - \\{ip}\c$
Psexec - cmd.exe - psexec \\{ip} cmd
Whether it's File Explorer or the command prompt, the argument parameters aren't being applied.
Is there something specific I need to do? Is there another way to write the commands?
Thank you.
Patrice
Re: Using "External Tools" (or plugins)
Published: November 28, 2019 - 12:47 PM
by agauvrit
The value to enter as an argument for PsExec would be this one:
-accepteula -i \\{ip} cmd.exe
Alexander
Published: January 2, 2020 - 3:21 PM
by Patrice_minagri
Hello Alexandre,
Best wishes for the new year ;)
. Regarding psexec, have you tested it as an external WAPT plugin? I haven't found a way to implement it.
If you have any tips or the exact syntax for what to enter, I'd be very grateful.
Thanks.
Patrice.
Published: January 3, 2020 - 10:28 AM
by sfonteneau
It works for us.
The way external plugins work is really very basic.
I don't see what the problem could be.
