Page 1 of 1
[SOLVED] Problem creating deployment package.
Published: November 29, 2019 - 10:25 AM
by KyleRayner76
Hello everyone,
I'm new to WAPT, so I'm still having a little trouble with some of the functions.
Here's my problem:
I need to deploy the "3DXML Player" software. Since it's not one of the pre-made packages, I'm using the WAPT package template creation wizard. However, after specifying the location of the software's executable file, I can't "create and upload" because it can't find the uninstallation key.
The problem is that I don't know what to enter in this field, so I'm stuck :cry: .
If someone could help me, that would be fantastic.
Thanks in advance and have a good day ;) .
Re: Problem creating deployment package.
Published: November 29, 2019 - 10:29 AM
by agauvrit
For *.exe files, there's no choice but to install the software to determine the uninstallation key; the "Create and Upload" function is only available for *.msi files.
https://www.wapt.fr/fr/doc/wapt-create- ... index.html
Alexandre
Published: November 29, 2019 - 11:41
by KyleRayner76
Okay, so I installed the software and retrieved the uninstallation key from the registry. I added it to the setup.py file.
But how do I add the software to the library?
Published: Dec 3, 2019 - 2:13 PM
by dcardon
Hello KyleRayner,
KyleRayner76 wrote: ↑Nov 29, 2019 - 11:41 AM Okay, so I installed the software and retrieved the uninstallation key from the registry. I added it to the setup.py file.
But how can I add the software to the library?
The best thing to do is to look at the documentation https://www.wapt.fr/fr/doc/wapt-create- ... index.html
If anything is unclear, you can open a specific thread.
