Page 1 of 1
Console improvements
Published: Dec 6, 2019 - 09:39
by Mathieu
I'd like to suggest a small improvement to the console.
For the "Package Groups," "Windows Updates," and "Self-Service Rule Packages" sections, when creating a new package group, for example, I'd like to add the option to configure the minimum OS version.
We have several groups that are specific to the OS version, for example, version 1709 and others for 1909.
The only solution I've found is to take the .wapt file from the server for the group I want to modify, extract it, then modify the control file and build-upload it using the command prompt.
This is mainly to limit the number of steps and use only the console without resorting to another method.
Thank you.
