Page 1 of 1
[SOLVED] Web Services Active Directory
Published: Dec 27, 2019 - 2:04 PM
by pirona
do you know if there are plans for Samba 4 to integrate Active Directory Web Services (ADWS), which would allow for a considerable number of additional PowerShell capabilities?
It's a big undertaking, so I imagine not, but just in case...?
I haven't found anything about it elsewhere on the web, but perhaps I haven't searched properly.
Re: Web Services Active Directory
Published: January 2, 2020 - 9:28 PM
by vcardon
Your preference is a matter of resources and priorities.
Otherwise, why not Python, which will give you the same results (unless you're using a third-party application that relies exclusively on the Windows AD HTTP APIs)?
Regards,
Vincent
Published: January 6, 2020 - 9:07 AM
by pirona
As a young padawan fresh out of school, I don't (yet) know Python.
So, I'd be interested in any hints that might point me in the right direction.
Published: January 6, 2020 - 3:24 PM
by agauvrit
Due to a misunderstanding, we found this in the Samba documentation:
https://dev.tranquil.it/samba/fr/samba_ ... samdb.html
This part of the documentation is still a work in progress, but it's already a good starting point if you want to use Python with Samba.
Regards,
Alexandre
Published: January 6, 2020 - 3:36 PM
by pirona
Thank you, that's exactly what I need!
Best wishes to the team, by the way.
Re: [SOLVED] Web Services Active Directory
Published: January 15, 2020 - 05:05
by mablehill
Hello @agauvrit,
thank you for your answers.
