Page 1 of 1
WAPT 1.8: Fight against heterogeneous parks!
Published: January 21, 2020 - 5:43 PM
by erenodau
🚨 WAPT 1.8 is FINALLY Available! 🚨
Find WAPT agents for Mac and Linux and a new tab to configure and manage your secondary repositories !
To discover WAPT 1.8 ➡️ : https://www.tranquil.it/wapt-1-8-luttez ... terogenes/
To try WAPT Enterprise ➡️ : https://www.tranquil.it/gerer-parc-info ... ayer-wapt/
⚠ Important information :
- WAPT Console - possible side effect: if the console admin password has not been reset since WAPT 1.6, it will need to be reset to use pbkdf2
- WAPT Console: In the inventory grid, the side panel is hidden by default and only appears when a machine is selected.
- WAPT Console: Packages awaiting update appear duplicated to display the old/new version of packages.
- WAPT Enterprise Server: Windows Updates are moved to the root of the waptwua/ folder on the server. This may result in a complete resynchronization of the replicated repositories.
- WAPT Server: WAPT package naming now includes an MD5 hash to speed up server-side package scanning.
To intentionally rename repository files: `wapt-scanpackages --canonical-filenames`
- WAPT Console: When generating waptagent.exe from the console, the certificate may not be copied to the ssl/ subfolder if the WAPT console is not launched with elevated privileges.
Our documentation is there to help you: https://www.wapt.fr/fr/doc/
Enjoy this new version!
Re: WAPT 1.8: Fight against heterogeneous parks!
Published: February 27, 2020 - 11:38 AM
by cbarille
Hello everyone,
Simon, our WAPT expert, explains the new features of this version in a video:
  • Remote repository management:
This new version allows you to transform a WAPT agent into secondary storageThis method allows for a significant reduction in bandwidth consumption: https://www.youtube.com/watch?v=MGe2ItyfxZY
  • Linux and Mac agent management:
Version 1.8 also allows you to manage Linux and Mac agents with WAPT under Windows. This new feature allows for simple and efficient administration of an IT infrastructure running on different operating systems via a single console that centralizes all data: https://www.youtube.com/watch?v=fsbj3Kt ... e=youtu.be
Have a good day, and see you soon!
