Page 1 of 1
[SOLVED] Linux agent installation error
Published: February 11, 2020 - 4:42 PM
by mart03
Specify the installed WAPT version (1.8.0)
* Specify the server's OS (Linux) and version (Debian Buster)
* Specify the OS of the machine used for administration/package creation (Debian Buster)
When I try to install the Linux agent, I get this error:
Preparing to unpack .../tis-waptagent_1.8.0.6641-debian-10-3dbb3de8_amd64.deb ...
User wapt already existing, skipping user creation
EXECUTING : /usr/sbin/usermod -g 33 wapt
usermod: no changes
Unpacking tis-waptagent (1.8.0.6641-debian-10-3dbb3de8) ...
dpkg: error processing archive /var/cache/apt/archives/tis-waptagent_1.8.0.6641-debian-10-3dbb3de8_amd64.deb (--unpack):
 trying to overwrite '/opt/wapt/bin/activate', which is also in package tis-waptserver 1.8.0.6641-debian-10-3dbb3de8
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Can you please tell me how to resolve this error?
THANKS.
Re: Linux agent installation error
Published: February 11, 2020 - 5:19 PM
by dcardon
Hello mart03,
mart03 wrote: ↑Feb 11, 2020 - 4:42 PM When I try to install the Linux agent, I get this error:
usermod: no changes
It seems you're trying to install the agent on the WAPT server itself, right? Currently, the two packages aren't compatible; you have to install either the agent or the server. We'll look into fixing this in a future version, probably 1.8.2.
You can try installing it on another Linux machine; you shouldn't encounter the problem.
Published: February 11, 2020 - 5:26 PM
by mart03
Yes, indeed... I thought the agent had to be installed on the server to be recognized by other repositories... my mistake then, it was a misunderstanding.
Thank you very much
