Page 1 of 1
[RESOLVED] PC STATUS DISCONNECTED
Published: February 24, 2020 - 9:00 PM
by Kavinus
In the console, some workstations are displaying the status "DISCONNECTED" even though they are reachable (ping OK).
Therefore, I cannot check for updates or launch installations.
However, I can connect remotely to the workstations without any problem.
Any ideas?
- Installed WAPT version: 1.8.1.6742 (Enterprise)
- Server OS (Debian 10 Buster)
- Administration/package creation machine OS (Windows 10 v19.09)
Kavx
Re: PC DISCONNECTED STATUS
Published: February 25, 2020 - 10:11 AM
by agauvrit
Is the WAPT service running on the workstation?
The green "dot" indicates the connectivity status of the WAPT service; if it is down or misconfigured, it cannot connect to the server and consequently the dot changes to DISCONNECTED status
To attempt a service restart
net stop waptservice
net start waptservice
Published: February 26, 2020 - 9:23 PM
by Kavinus
Thanks for your feedback, "agrauvit".
It worked for most of the computers, but the problem persists for some.
There are some that don't have the "empty column" indicator at all.
Thanks for your help.
