WAPT Community 1.8 installation on LINUX DEBIAN buster 10.2 - psql error 5432
Published: March 2, 2020 - 2:41 PM
I'm trying out the WAPT Community version before trying the Enterprise version.
I'm following the software installation documentation on Debian, but I'm encountering an installation problem when running the installation script: /opt/wapt/waptserver/scripts/postconf.sh.
I checked the forum before posting this but didn't find a solution I could test.
Do you have any idea what the problem might be with psql? Is it a firewall issue? Do I need to manually modify a psql configuration file?
Thanks in advance!
I'm getting the following error as root:
Synchronizing state of postgresql.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable postgresql
psql: could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
File "/opt/wapt/waptserver/scripts/postconf.py", line 702, in
main()
File "/opt/wapt/waptserver/scripts/postconf.py", line 423, in main
ensure_postgresql_db(db_name=server_config['db_name'],db_owner=server_config['db_name'],db_password=server_config['db_password'])
File "/opt/wapt/waptserver/scripts/postconf.py", line 191, in ensure_postgresql_db
val = run(""" sudo -u postgres psql template1 -c " select usename from pg_catalog.pg_user where usename='wapt';" """, cwd='/opt/wapt')
File "/opt/wapt/waptserver/scripts/postconf.py", line 66, in run
return subprocess.check_output(*args, shell=True, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 223, in check_output
subprocess.CalledProcessError: Command ' sudo -u postgres psql template1 -c " select usename from pg_catalog.pg_user where usename='wapt';" ' returned non-zero exit status 2
debug:
root@WAPTC:~# psql
service postgresql status
● postgresql.service - PostgreSQL RDBMS
Loaded: loaded (/lib/systemd/system/postgresql.service; enabled; vendor preset: enabled)
Active: active (exited) since Mon 2020-03-02 14:13:19 CET; 13min ago
Main PID: 486 (code=exited, status=0/SUCCESS)
Tasks: 0 (limit: 2346)
Memory: 0B
CGroup: /system.slice/postgresql.service
Tue 02 2:13:19 PM WAPTC.****.*** systemd[1]: Starting PostgreSQL RDBMS...
Tue 02 2:13:19 PM WAPTC.****.*** systemd[1]: Started PostgreSQL RDBMS.
root@WAPTC:~# localectl status
System Locale: LANG=en_US.UTF-8
VC Keymap: n/a
X11 Layout: fr
X11 Model: pc105
X11 Variant: latin9
Thanks in advance!
main()
debug:
root@WAPTC:~# psql
Memory: 0B
VC Keymap: n/a
X11 Layout: fr
X11 Model: pc105
X11 Variant: latin9
