Clean Zoom Package
Published: April 9, 2020 - 1:11 PM
Hello everyone,
following the controversies and revelations about Zoom:
https://www.journaldunet.com/web-tech/g ... ui-craque/
So we had to search for a way to easily clean it up on our network (installed for many in AppData).
Zoom offers an uninstaller: https://support.zoom.us/hc/en-us/articl ... anZoom.exe
Here is the package code:
The version with scanning via audit (Enterprise) with installation space management via the control file (installed_size):
If this can help you make your parks safer
install_exe_if_needed("CleanZoom.exe",'/VERYSILENT',key='',min_version='6.5.64722.0907')
#Présence de Zoom
ifZoom = 'False'
#Récupération de tous les utilisateurs
AllUsers = glob.glob('C:\Users\*')
#Récupération du contenu AppData
for User in AllUsers :
FolderAppData = glob.glob(User + '\AppData\Roaming\*')
#test de la présence du dossier Zoom
for Folder in FolderAppData :
FindZoom = Folder.find('Zoom')
if FindZoom != -1 :
ifZoom = True
#Récupération de l'espace disponible
Freespace = get_disk_free_space('C:')
#Récupération de l'espace nécessaire à l'installation
Control = PackageEntry().load_control_from_wapt('.')
Usespace = Control.installed_size
#Test si place disponible
if Freespace > Usespace :
filecopyto('CleanZoom.exe',makepath('C:'))
if ifZoom == True :
remove_file("C:\CleanZoom.exe")
def audit():
if ifZoom != False :
killalltasks('Zoom.exe')
install_exe_if_needed("C:\CleanZoom.exe",'/VERYSILENT',key='',min_version='6.5.64722.0907')
return "WARNING"
else :
return "OK"
